Asuswrt official iptables-save not saving changes permanently
savage75
Hi folks!
Trying to set a rule on iptables for nat permanently but no luck ?
iptables -t nat -A POSTROUTING -s 10.2.0.0/24 -o br0 -j MASQUERADE
I tried using
iptables-save -t nat
or just
iptables-save
but still no success and every changes will disappear after restarting ??
any ideas how I can solve this ?
thanks
iptables-save does not "save" anything. It just dumps the rules so that they might be read by a human or another process.
Starting any line with a # character means that it's a comment and what follows on that line is ignored. So the following two lines do nothing at all:
#iptables-save -t nat
# blah blah blah
I'm not aware of a way on stock firmware of making permanent changes to the firewall rules.
# blah blah blah
ahha! sorry that was a mistyped. I don't run these commands by # so thats not the issue.
so if I understand right there is no way to solve this ?
I'm running wireguard vpn and it needs changes for nat so I can reach my local network connected devices
is there a way to run this when the connection to the VPN is UP?
or any other suggestions
ok thanks but could you describe how can I add the role above as a route? because I tried it before but no luck.
here is the route looks like what I need to add for GW, Metric and Interface?
For anyone wondering I posted the solution here
