Geoblocked24
Hello,
I have ATT Fiber with BGW320 Gateway when directly connected to a router results in corresponding devices on the network (mobile/laptop/desktop) being unable to access a variety of websites like sling.com and other innocuos websites. The error message when browsing the web is that you are located in a non-US country so you're blocked. I am in the united states. This problem happens with either an ASUS Wireless Router or a Netgear Wireless Router. If I directly physically connect the device to the AT&T Gateway then I can access these websites, if I use any router connected to the gateway I get the blocked message.
ATT Support was less than helpful indicating since direct physical connection or ATT wifi was operational that this was a router problem. Although the same issue happens with all routers connected to the gateway.
I'm wondering if there is some setting I *must* now set on the Gateway in additon to pass through to resolve this, or if there is something needing to be configured on routers when connecting to a gateway.
Thanks for any advice or suggestions.
