Aura RGB LED Scene Application Script
aru
Is there a script to control indicator lights, for example, turning off all lights to mimic a black box when everything is normal, displaying a red light when the system is abnormal, briefly flashing a red light during a DoS attack, flashing a green light when a client is connected, and displaying a marquee effect when CPU load is high?
Simple answer — no.
It feels very practical; I wonder if anyone is interested in developing it... :)
You should look into @JGrana's Hue light script.
If I had a model that features the aura light I would dabble in it and integrate it into the amtm LED script.
I have a few example scripts that use huetil to show download speeds and another that shows CPU load. They use a few Philips Hue bulbs and the above mentioned huetil script to control the colors.
Look in the examples directory in my github for hueshowspeed and hueshowload
