pete y testing
hi guys
have installed
Version 2.1.1.4
Description ASUS PCE-AC68 Utility 2.1.1.4
It is for all sku except EU
Support OS: Win 7/8/8.1/XP/10
Updated driver version to 7.35.315.0
[Please note]This version is driver only. Before installing this version, please uninstall pervious PCE-AC68 utility
File Size 89.11 MBytesupdate
and although the 5 gig side of it is working fine no matter what i do or try i cant get the adapter to connect on the 2.4 gig above 216M sync rate
i have confirmed the 2.4 gig is set to 40mhz and obss co existence is disabled on the router and inssider is showing the router ( various routers ) is using 5 channels and thus 40mhz but its like the adapter its self is forcing obss coexistence
can anyone that has the pce-ac68 install this if they have windows 10 64 bit and see if the same occurs
i will chase this up with asus as well , just wanted to check with some other users first
thanks
pete
have installed
Version 2.1.1.4
thanks
pete
