Hello!
I'm having trouble to authenticate with my Cisco WAP4410N AP to my radiusserver (Debian6).
The thing is i'm using LDAP to login to the wireless network, which seems to work because i can do:
radtest testuser "password" \ localhost 2 testing123
Where testuser is an LDAP-user.
Where i get an "Access-accept" answer.
But when i then try to login to the wireless network, radius refuses to accept the Cisco AP. Which in follow blocks every attempt to login.
Current errormessage is printed by freeradius -X
I have added an entry for the AP in clients.conf which looks like following:
Does anyone on have a clue on where I did go wrong with this, and what I can do to fix this.
Thanks in advance
/skrollan
++[eap] returns ok
Found Auth-Type = EAP
# Executing group from file /etc/freeradius/sites-enabled/default
+- entering group authenticate {...}
[eap] Request found, released from the list
[eap] EAP/peap
[eap] processing type peap
[peap] processing EAP-TLS
[peap] eaptls_verify returned 7
[peap] Done initial handshake
[peap] eaptls_process returned 7
[peap] EAPTLS_OK
[peap] Session established. Decoding tunneled attributes.
[peap] Peap state send tlv failure
[peap] Received EAP-TLV response.
[peap] The users session was previously rejected: returning reject (again.)
[peap] *** This means you need to read the PREVIOUS messages in the debug output
[peap] *** to find out the reason why the user was rejected.
[peap] *** Look for "reject" or "fail". Those earlier messages will tell you.
[peap] *** what went wrong, and how to fix the problem.
[eap] Handler failed in EAP/peap
[eap] Failed in EAP select
++[eap] returns invalid
Failed to authenticate the user.
Using Post-Auth-Type Reject
+- entering group REJECT {...}
[attr_filter.access_reject] expand: %{User-Name} -> host/robert-laptop
attr_filter: Matched entry DEFAULT at line 11
++[attr_filter.access_reject] returns updated
Delaying reject of request 59 for 1 seconds
Going to the next request
Waking up in 0.9 seconds.
Sending delayed reject for request 59
Sending Access-Reject of id 55 to 10.0.0.3 port 2070
EAP-Message = 0x04080004
Message-Authenticator = 0x00000000000000000000000000000000
Waking up in 3.9 seconds.
Cleaning up request 51 ID 47 with timestamp +2345
client 10.0.0.3 {
secret = testing123
shortname = wireless_ap
nastype = cisco
Thanks in advance
/skrollan
