rudiantoine
Good morning, do you have experience with the Ax-6000 and IPv6? Is it true that IPv6 is not compatible with the Asus Ax-6000? And if so, has Merlin perhaps overcome this issue?
It can often come down to the routers as well though. Many people are having problems with Vodafone UK's "Native" dual stack, but it seems only when using Vodafone's own router. My asus hasn't skipped a beat since I was provisioned, using noip (AAAA) DDNS.Im in the UK using a GT-AX6000 on BT 900/100. I've IPv6 enabled on "native" and it works fine for me. I have DDNS enabled via DynV6 with direct access (when I choose to enable it - which is very rare) to an internal server. Often the issues with IPv6 seem to come down to the ISP implementation, and there are people on BT Broadband who do have issues, I'm just not one of them!
PPPoE here. @Crimliar Do BT use PPPoE for their connection.Thanks for the answers, but reading the FAQ in the Asus manual, it specifies that with PPPoE it is not possible to use IPv6. I would like to know if Merlin is aware of this issue and if a patch is planned. Or if switching to IPoE would solve this problem.
I see where you get that ideaThanks for the answers, but reading the FAQ in the Asus manual, it specifies that with PPPoE it is not possible to use IPv6.
Ah, ok! Now it might be clearer. I just mistranslated, in my mind, what was described in the FAQ. Tks!I see where you get that idea
You may be mid-reading this, and I can see why. Your IPv4 connection will be PPPoE, the IPv6 should be set "Native". All the above is saying is that PPPoE is not available in the IPv6 settings.
Welcome To SNBForums
