Thw0rted
I've been running a 3xAX-92U mesh for a couple of months now -- all on (official) firmware 3.0.0.4.386_40451-g30f1b6c. The configuration is mostly stock, in Dual Band Smart Connect mode, channels manually specified on both bands, 1@20MHz and 36@20/40/80MHz. One node is on wired backhaul, the other is on the 5-2 band. Connections are solid for all my devices, *almost* all the time.
Every once in a while, one of my devices simply can't get on the network -- no configuration changes, either on the device or the router(s). The weird part is, the device thinks that the connection is successful -- "Connected, No Internet" in Windows -- but no traffic goes through. I haven't busted out wireshark yet, but I can't pull a DHCP address, and if I assign a static IP, I can't ping any other devices on the network. The other weird part is that I've had very similar symptoms on 3 Windows laptops and two Rokus, but never all at once, just one or two at a time, and sometimes they all work fine.
I don't think there's anything relevant in the system logs. I posted here a while back when the problem started, after which it sort of cleared up on its own, but in the past week or so it's been happening more often. I'd really like to figure out how to keep this from happening in the future.
