AX11000 Poor 2.4GHz Performance
hyelton
Recently I noticed my 2.4GHz network is useless not sure for how long since I only really had used it for IoT devices.
Same room as the router 150mbps with 20mhz bw setting.
Leave the room next to it. 3mbps...
Downstairs connected but no zero data throughput
In comparsion to 5GHz Same room 900mbps
Room next door - 600mbps.
Downstairs - 80mbps.
Default settings fresh reset and even firmware reflash running merlin 386.3_2
Channel doesnt make a difference. Only 1 other WiFi network on 2.4ghz on channel 1 so its not congestion.
Low end router on 2.4GHz performs as expected and normally.
Any ideas?
In other stress testing about 450ft away outside even 5GHz is a champ and performs decently while 2.4GHz nothing.
Here’s the settings I use on my gt-ax11000
But airtime fairness being on sounds like the most probable thing.
Its disabled. Oddly when switching to 40MHz it fixes the issue. But putting it back down to 20MHz it breaks it again.
At 40mhz its pulling 400mbps (impressive for 2.4GHz) in the same room and 200mbps in the next room and works downstairs.
Not sure why. But if your not living in a wifi congested area 40Mhz is better and say if you have a device that can only use 20Mhz then it will still only use 20Mhz of that 40Mhz.
