Just setup a new AX58U to replace my very old TP-Link N600 from 2012. I want to set it up so that my VR headset which supports Wifi6 is the only think on that channel so I can play PC VR Games.
I've search the forum as well as google but most tutorials show setting it up with TP Link AX Routers.
Was wondering if anyone here has this VR headset and is running it with an ASUS AX router (since the Asus login software should be similar to most models) can tell me how to limit the wifi6 channel to just the VR Headset as well as the best overall settings to adjust to achieve the best wireless stream for it.
