AX6000 to AX86U via 2.5Gbps LAN
frequenzy
I have directly connected AX6000 to AX86U using the 2.5Gbps ports. Status shows 2.5GBps. But when I performed iperf3 between them the speed is just 1.2Gbps. See screenshots below. Is this expected?
Server
Client
Your router's CPU is probably unable to keep up with the iperf data. Run it from another endpoint instead.
