All,
It seems there is a common problem with our ax86u routers (and nest thermostats getting or maintaining successful connections through the router. I dont think this issue is regulated to just the AX86u router but probably other asus routers as well.
here’s a few examples:
https://www.snbforums.com/threads/r...-nest-thermostat-cannot-connect-solved.61284/
And it seems there’s many others sprinkled around this forum as well. I wanted to try and see if we can combine the efforts to one singular place to help out other users. I’ve tried so many things that I’ve lost track of what I’ve done and now where to go. At one point I had it working and it stayed connected for a few days, and then stopped now I can’t access the thermostat at all from the web or iOS clients. These clients just say it’s offline. None of these issues happened until I upgraded from my failing netgear r7000p router with this new asus router.
The weird thing is that the thermostat says it’s connected, but It won’t actually make successful connections to the internet (I verify this by checking for a software update on the thermosta) and of course I can’t then control the using The iOS app or the nest website.
Has anybody got their nest thermostat to stay reliably connected to their ax86 (or similar) router ?
