Anyone knows the difference ?
My question is there a way to save my vpn configurations.
The Pro has a faster CPU and more RAMWas about to get the AX86U then my friend said there is a pro version , Anyone knows the difference ?
and more RAM
Website shows two models of AX86U (non-Pro) one with same and other with less.No, it doesn't have more RAM.
Were I do migrate from one to the other I would do a side by side. My iPad would access the configuration panels of the AC via WiFi. I would plug the AX into an Ethernet port of my MacBook and access configuration panels. Just be sure to temporarily use a different name for the SSID of AX. Once AX is configured power off the AC, change the SSID of the AX to what it should be, save config, power off, and swap routers.My question is there a way to save my vpn configurations.
Otherwise i will have screen capture all of it
AX86U and AX86U Pro both have quad-core CPU, 1GB RAM and single 2.5GbE port.
Faster processor!
Agreed 0.2 GHz isn't a big deal. For some people it's about the numbers but for others it's the delta in price.We know this already. Not a big difference though and not worth the extra money as CPU upgrade alone. What may worth purchasing AX86U Pro is perhaps longer expected support. The hardware is newer and in line with all Asus high-end models. Whoever already has AX86U - keep using it.
what is it the AVERAGE HOME user actually needs?
At a marketing level, I agree.I do not consider the GT-AX6000 as a successor to the RT-AX86U, as it`s in a totally different price bracket, and also it`s part of their ROG product line. The RT-AX86U_Pro is the actual successor to it, and should be priced close to what the RT-AX86U initially was launched at.
Thanks think i will flash merlin first then set it upWere I do migrate from one to the other I would do a side by side. My iPad would access the configuration panels of the AC via WiFi. I would plug the AX into an Ethernet port of my MacBook and access configuration panels. Just be sure to temporarily use a different name for the SSID of AX. Once AX is configured power off the AC, change the SSID of the AX to what it should be, save config, power off, and swap routers.
Welcome To SNBForums
