AX86U Pro AIMESH router in AUTHENTIFICATION METHOD set to http & https will not able to access remote AIMESH node
welim
Dear All,
My AIMESH router is AX86U-PRO and my AIMESH node is AX11000.
Recently after the merlin firmware update to the 388.8.0 , I found something weird. My authentication method is setup to be both http/https (Administration->System->Authentication Method -> BOTH)
1. When I click upload firmware for the remote AIMESH node (trying for the 388.8.2) and login, it will indicate detecting and then said GT-AX11000 suggest
(a) Ensure that your AIMESH router has been powered on
(b) Reboot your AIMESH router and try again.
2. Despite what I do, it will not work. It will keep indcating the "Unable to connect to the Parent AP"
3. I go to AIMESH router AX86U-PRO and then set the authentication method back to "http" only and then try again, it will work.
Anyone aware about this problem and will this be fix ?
Best Regards,
WH
You have discovered the solution. Do not use https! There is no real need for the additional security of https inside a network, LAN, that you control.
thank you Ripshod. But earlier firmware can support. If I use ddns to remotely access the router , I used to use https://<ddns>:8443 . Would there be an issue if I use http:// now to access the aimesh router via wan?
Best Regards
Wee How
It's a bug, report it to 388.8 release thread.
Don't open Web access from WAN, security issue.
