Hi everyone.
I'm not an expert but I need some help.
I have used an RT-AC68U with satisfaction since 2015 and I kept it updated with Merlin firmware but, unfortunately, after the last firmware update, it was afflicted by the low free NVRAM error and, having understood that it was now starting to be obsolete, I bought a new AX86U PRO. And here the pain begins.
I configured the AX86U PRO to mirror the AC68U but I have problems with the attached 2TB disk and the configuration of SAMBA network resources.
While configuring the USB Application - Network Place (Samba) Share / Cloud Disk exactly in the same way it seems that nothing is activated with AX86U PRO. No resource is visible neither from Windows nor from Android while if I reconnect the old AC68U everything works fine.
I have read several posts in the Forum about the SMB configuration problem on AX86U but they all concerned some parameter not configured either on the router (SMBv1 - SMBv2 - account names) or on the PC (SMBv1 or network credentials).
In my case everything is configured in the same way: the disk is the same, the PC is the same, the configuration is the same... only the router changes! Is there a bug in the firmware?
Haven't tried the stock firmware yet.
I have a doubt: I have configured both routers mirroringly so I have the same internal and external IP address and the same login name (admin) and password. Does this fact imply something with the network credentials on windows 10 when the mounted router changes?
Any other suggestions?
