AX86U WiFi speed
Irenty
Witam wszystkich.
Mam internet z multimedi z modemu technicolor CGA4236TCH1 i podłączony AX86U do portu Lan w technicolor do portu lan w AX86U. Szybkość po kablu na AX-ie to trochę ponad 600Mb/s ( na tyle umowa tzn. na 600) a WiFi z AX-sa to od 250-300 Mb/s na laptopie i tak samo na komórce. Jak przełącze się na WiFi na technicolor to idzie na laptopie czy komórce ponad 600Mb/s. Czy to normalne czy coś mam źle ustawione na AX86U?
Hello everyone.
I have internet with multimedia with a technicolor CGA4236TCH1 modem and I connected AX86U with a LAN port in technicolor with a LAN port from AX86U. The speed via cable on AX is up to just over 600Mb/s (at the end of the contract, i.e. 600) and WiFi from AX is up to 250-300 Mb/s on a laptop and the same on a mobile phone. How do I connect to WiFi in Technicolor to go over 600Mb/s on a laptop or mobile phone. Is this normal or do I have a solution on AX86U?
Check the clients' Tx and Rx rates in System Log - Wireless Log. Also check the "Chanspec:" on the same page.
