ppat
Hello folks,
I am in definite need of some serious help with my new AX88U, please do read through what I have tried so far.
I am having internet drops (ASUS router status shows: "Internet disconnected"), and for some reason if it does manage to stay up for a while then it stops working with "Your ISP DHCP does not function correctly".
Somehow these two seem to be a more than usual occurrence and so yes I went through the following threads:
1. https://www.snbforums.com/threads/rt-ax88u-router-behind-modem-router-isp.67312/
2. https://www.snbforums.com/threads/rt-ax88u-internet-status-disconnected.67331/
3. https://www.snbforums.com/threads/a...-isps-dhcp-does-not-function-correctly.61902/
4. https://www.snbforums.com/threads/your-isps-dhcp-does-not-function-correctly.43178/
5. https://www.snbforums.com/threads/a...or-isps-dhcp-did-not-function-properly.61907/
6. https://www.snbforums.com/threads/new-rt-ax88u-no-wan-4-days-later.57960/
I was unable to come to a conclusive answer for this problem as some of these threads are not resolved and/or are going off topic now.
My intention with purchase of this router was similar reason as to thread 1 (handle VPN connection -PrivateVPN), use a hard drive in usb as a 'shared drive'. My problems are similar to above thread 3,4 and especially 6.
SETUP:
Internet -> Virgin(Bell) Valerie Modem/Router -> AX88U
Firmwares I tried with the settings below:
1. AX88U firmware upgraded to the latest ASUS. - NO INTERNET
(Rebooted manually/automatically every time I changed settings)
2. RT-AX88U_384.19_0 Asuswrt-Merlin. - CURRENT - NO INTERNET
ISP Virgin Valerie modem/router:
does not have an exact "Bridge mode".
Advanced DMZ : I put AX88Us' MAC address.
DDNS: OFF
UPnP: ON
DLNA: ON
DHCP: ON (Router IP 192.168.2.1)
Port Forwarding: None
WPS: OFF
MAC Filtering: OFF
DNS: Automatically
WAN: Auto
AX88U Settings:
Adaptive Qos: OFF
OpenNAT Enable port forwarding: OFF
802.11ax / Wi-Fi 6 mode: Enabled
Wi-Fi Agile Multiband: Enabled
Target Wake Time: Enabled
Protected Management Frames: Capable
160 MHz: Enabled
WPS: OFF
LAN IP: 192.168.50.1
Subnet Mask: 255.255.255.0
DHCP: Enabled
IP Pool Starting Address: 192.168.50.2
Default Gateway: 192.168.2.1
Advertise router's IP in addition to user-specified DNS: YES
Enable Manual Assignment: NO
DNS Filter: OFF
IPTV: None
WAN Connection Type: Automatic IP
Enable WAN: YES
Enable WAN: YES
NAT Type: Symmetric
Enable UPnP: Yes
Enable secure UPnP mode: Yes
Enable WAN Aggregation: NO
Connect to DNS Server automatically: Yes
Forward local domain queries to upstream DNS :Yes
Enable DNS Rebind protection :Yes
Enable DNSSEC support : No
MAC Address Clone: Nothing (Tried using the LAN and WAN mac of AX88U here but no internet)
DHCP query frequency :Normal Mode
Extend the TTL value :Yes
Spoof LAN TTL value :Yes
Enable the DDNS Client :Yes
VPN: OFF
Have PrivateVPN client configured and worked somethimes VPN and internet(triple checked). But now no point without internet.
What am I doing wrong? Is it router or my understanding of settings is no bueno eh?
Kindly advise, please and thank you.
SETUP:
DDNS: OFF
UPnP: ON
DLNA: ON
WPS: OFF
MAC Filtering: OFF
DNS: Automatically
WAN: Auto
AX88U Settings:
Adaptive Qos: OFF
160 MHz: Enabled
WPS: OFF
DHCP: Enabled
DNS Filter: OFF
IPTV: None
Enable WAN: YES
Enable WAN: YES
NAT Type: Symmetric
Enable UPnP: Yes
VPN: OFF
