Christophe
I've been running on an old AC3200 with an AC68U access point attached for a while now and have had generally great experiences.
I recently upgraded to an AX88u placed in center of the house, and the signal strength is goo throughout. I have many Amazon Echo devices which I was able to get registered. I also have many smart devices (dimmer switch, smart plugs, Hue, Smart lights connected) I have found a few things that either do not work at all, or ONLY sometimes work.
Issues:
1) I have a smart plug by CE Smart that simply will not connect to the AX88u. I've been able to connect it to ISP Modem Wifi (SmartRG 516).
This is a 2 Ghz device, and I am using the 2Ghz SSID - and the ASUS channel I use is much stronger an less congested than the SmartRG channel.
2) *** the most annoying symptom *** - My Amazon Echo devices (different generations, and models) all connect and respond to commands, but
streaming media is really hit and miss. For example, when I say "Alexa play BBC radio 2 on Tune-in", Alexa responds "playing BBC radio-2 on Tune-in"
but then there is just silence. Sometimes it does work - but then cuts out a bit later. I've had similar results with "Play Frank Sinatra on Spotify".
The ability to play music to speaker groups has not been a huge success either - sometimes works, sometimes not.
Set-up:
1) AX88U Merlin f/w 388.1
2) AI-Mesh - not used
3) Smart Connect - off
4) Wireless mode - Auto
5) 802.11ax - disable (I don't need this now, but had issue on or off...)
6) Agile Multiband - Disable
7) Target Wake Time - disable
8) Channel bandwidth 20/40
9) Control Channel 4
10) Extension channel - Above
11) WPA-2-Personal / AES
12) Protected Management Frames - Disable
13) Group Key Rotation - 3600
I've tried with the devices either on my LAN SSID or on a Guest Network SSID. I did not try Amazon WiFi simple setup because I could not find any description of how to use it.
My wife is getting a bit agitated with the on/off of the network and missing her beloved BBC - But I'd hate to have to revert back to the old AC3200 switch which is not even supported anymore.... all suggestions welcome.
Issues:
Set-up:
