AX88U port forward troubles.
Cal
Hi all,
I’m absolutely stuck trying to get port forwarding without upnp. I just want to open two ports for a Linux desktop connected via Ethernet.
DHCP server is enabled.
I’ve assigned a static ip to the computer. It works fine.
I‘be assigned 9001 to the virtual server with both TCP/UDP
the firewall is on but does appear to make a difference.
I’m absolutely stuck for ideas. Any guidance?
