Ax88u pro wall mount
wol-shiver
Received ax88u pro in replacement of an ax88u today under warranty. I'm uncertain why they Indicate it's not wall mountable, or some reviews state it doesn't have the slots. It had the exact same slots as my ax88u and fit right into its spot.
Please no judgement as to placement, it's where I want it and it's quite cool inbetween floors per the ajaxcoretemp.
Thanks.
Thanks.
What failed on the old AX88U?
OE
OE
The router died completely unfortunately. No electrical issues or thunder/lightning/other that I know of.
I took my main ax88u router which was in the position seen in the photo, and moved it to where the failed node was in the living room, upgrading ever so slightly my aimesh router (was 2x ac88u now 1 pro/1 non pro.
Few Reddit threads, dong knows tech, etc, they mention the holes below the rubber inserts aren't slotted to receive a screw.
