Tubbs Tattsyrup
My ax88u is running with AsusMerlin 386.3.2 with a mix of clients including several Sonoff Tasmota devices.
Every so often, one of the Sonoff Tasmota devices loses connection. When I look in Network Map, devices, wifi, 2.4, I can see the device, briefly, before it disappears, only to reappear a few seconds later. This then continues in this cycle until I reboot the router. After a reboot the device connects, but, after a while, one of the other Sonoff Tasmota devices looses connectivity as above.
A week ago I did the nuclear reset and rebuilt the router from the bottom up. All was well for a couple of days, but it has now started to occur again. Only ever with the Sonoff Tasmota devices.
I thought that this may be a DHCP problem, to do with the number of clients, so I tried the YASDHCP add on. The same thing occurred. I have clients (approx 10 on 2.4 GHz, 6 on 5GHz and 4 wired connections.
I also have a AX68U router as a mesh node running.
I would appreciate any ideas of a solution or similar experiences from others as it is driving me quite mad.
Thanks in advance for any pointers.
