I have 2x AX92u currently on the latest firmware 3.0.0.4.386_41535 and am having issues with wifi randomly dropping and having to reboot the router (I reboot by going through the router page) and everything works fine again afterwards.
There are no issues with the wired connection, so sometimes I do not even know the wifi connection dropped.
This issue was happening on the prior firmware as well.
I did a reset today by holding the WPS button on both the router and node. I setup the router and mesh node again using mainly the default settings.
Changes made to default:
I have turned off WPS, WMM APSD, 802.11ax / Wi-Fi 6 mode. DHCP query frequency set to Normal.
I am cloning my desktops (wired) Mac Address, as that seems to be the only way for the internet to work with Xfinity, otherwise I will get that DHCP error.
I do have around 18 or so clients connected to the routers (Ring alarm/doorbell, cameras, phones, laptops, smart speakers)
I do see (few minutes before wifi drops) like around a 100 or more of the line below showing all the different mac addresses of my devices. Almost all devices are connected to the main router and not the node as well.
Jan 4 15:47:51 wlceventd: wlceventd_proc_event(490): eth6: Deauth_ind _____________, status: 0, reason: Class 3 frame received from nonassociated station (7), rssi:0
I just tried making these changes to see if this will help with the constant disconnects to see if it will make any difference.
I have SmartConnect on and manually set the Control Channel (it was Auto before), hopefully auto has been the issue but will see.
I don't recall this issue happening 2 firmware versions ago, so I am not sure if I should try to downgrade firmware instead and try that.
Any help would be appreciated. I tried to search up the error from the system log but can't seem to find how to resolve the issue.
Thanks,
Alvin
Thanks,
Alvin
