I have a 2Gbps connection with Xfinity. When running a speed test on the AXE-16000 router I am getting anywhere from 1500 to 1650Mbps.
I tested the speed between my Macbook pro and Asus AXE-16000 using iperf3 and I see ~1.5Gbps speed (seems like my home network is not too great)
I expect to see close to ~1.48 Gbps when I run a speed test on the router as the router is able to hit 1.5+ Gbps directly with the cable modem. But I see really poor speed test speeds. I have tried multiple speed testing sites and none of them go above 600Mbps. Here is a sample to speedtest.net
I am totally puzzled about why this is happening. I tried connecting directly via Wifi while sitting right next to the router using my phone and it is not able to go past ~600Mbps either. So I suspect there is something wrong on the router and I am clueless how to troubleshoot this further.
Note: I am running the Beta firmware 9.0.0.6.102 on the router as I need the "Guest Network Pro" and I have created one vlan for all my IOT devices. I am not sure if this is what is causing the problems, but I thought that this is worth mentioning.
Any help trying to resolve this problem would be much appreciated!
Edit: Editted for clarity
