Hello. Asus AXE1600 running 3004.388.8_4 current latest.
Tried looking at previous posts, could not find simple guide to get me started.
I've connected an external USB drive. It's detected in Asus GUI fine.
1. What format should I use? GUI has FAT/NTFS/HFS. I've seen other posts with people using exfat/etc.
2. I want to also use the NFS share option but that does not work with NTFS, decided to post here first.
3. Aim is enabled scripts to be stored on USB drive, NFS shares & eventually run AMTM scripts like dual switcher, try some monitoring scripts.
If possible want to be able to have NFS + CIFS/SMB shares.
Currently:
Persistent JFFS2 partition | Enable JFFS custom scripts and configs = No.
Currently:
