Backing up USB drive to Mega cloud storage
vrapp
Can someone suggest a solution to backup the files from USB-connected storage (serving as household network storage) to Mega cloud storage? It looks like there are some tools already like megacmd , but I don't see it in entware and I'm not savvy enough in Linux to put it to work without it.
I can back it up using Mega's Windows client, but it would be better to have it right on the router.
Doesn't appear here either, is it possible it wasn't picked by entware-ng yet?
For the record, if anybody finds this thread looking for the same: by now meganz-sdk is indeed available from entware-ng. I was able to successfully install it, and scheduled synchronization of a directory from the attached USB drive by putting this into post-mount:
export MEGA_EMAIL=(your MEGA logon)
export MEGA_PWD=(your MEGA password)
megasimplesync (local directory) (remote directory) &
Another command from the SDK - megafuse - allows mounting remote MEGA directory as local.
