Backup / Restore procedure prior to installing newer firmware to same router
Denna
Scenario:
You have a router running Asuswrt-Rmerlin that is fully configured and working.
You want to install a newer firmware version of Asuswrt-Rmerlin.​
1) What method should be used to fully backup the configuration of the router so that it can be restored after installing the newer firmware ?
2) Does installing a newer version of Asuswrt-Rmerlin overwrite existing configuration values ?
The existing configuration is preserved. You'll want however to ensure you keep a backup of the JFFS partition if you created any script or custom config files in it. And if you're upgrading from a much older firmware, it's recommended to do a factory default reset, and manually reconfigure everything.
and to be safe do this everytime ? well at least thats what i do as it clears any bad configs from previous fw , yes a bit over the top but how long does it take to manually redo it anyway ;)
Upgrading the firmware means you're completely starting over, correct ?
No.
https://www.snbforums.com/threads/faq-nvram-and-factory-default-reset.22822/
To completely start over you need to do a full reset to factory defaults after flashing the firmware you want installed (you many need to do this step twice; it has helped many with random and persistent issues) and then minimally and manually configuring the router to secure it and connect to your ISP ;
https://www.snbforums.com/threads/n...l-and-manual-configuration.27115/#post-205573
https://www.snbforums.com/threads/rt-ac66u-slow-wan-to-lan.12973/page-3#post-269410
