BACKUPMON BACKUPMON v1.5.10 -Mar 1, 2024- Backup/Restore your Router: JFFS + NVRAM + External USB Drive! (**Thread closed due to age**)
@Viktor Jaep Thank you for continuing to improve this great utility.
I have a request for another feature addition: Please consider the ability to launch with an alternate config file in order to allow backup to an alternate destination. My thought is that I could backup to a remote server in addition to a local server in order to provide offsite backup.
Nice! I'll start putting some thoughts around how to handle this... ;)
Question. Can we just add the -backup switch to /jffs/scripts/services-start as the script doesn't seem to do it?
In fact any changes I make to the configuration don't seem to make it through to the cron job or services-start. It's not a headache, I can edit the cron myself (which is fine), but it just doesn't seem to be behaving the way I assume it's designed to. backupmon.cfg doesn't seem to exist anymore?
It's not meant to run from services-start as it's a run and done type of script. What kinds of changes are you trying to make that aren't reflecting?
The cfg lives under /jffs/addons/backupmon.d
If I change the time of the backup in backupmon it gets changed in the config file, but that's not reflected in the cru a line added to services-start
Oh I see what you mean... the cru command itself. Hmm. Yeah, it looks like you'd need to disable auto start, and then re-enable it for the time to stick. I'll get that fixed.
standing by...
I would add this script in a heartbeat to amtm and will in fact do so next time I fire up the Workhorse and do some coding.
The release will be delayed however as I already made significant changes in amtm for the upcoming Diversion update. Both updates are tied together as it stands now.
As always y’all will have to be patient. Take a hike Go on a hike, read a book, treat your significant other well and don’t waste time on YouTube as apparently I do.
As always y’all will have to be patient. Take a hike, read a book, treat your significant other well and don’t waste time on YouTube as apparently I do.
Telling your users to "Take a hike"?!? Love it! 😘
Two updates a day keeps the bugs away! Fixed that issue that @Ripshod found, and fixed some CRON-related bugs at the same time! And yeah, if you want to add switches to the services-start cru command, you'll need to add those manually... and probably just keep the scheduler disabled since that's a power user move! :)
What's new?
v1.17 - (September 18, 2023)
- FIXED:
Bugs associated with adding a CRON job were found while adding the request that @Ripshod made note of, and now updates the cru job with the correct time if you happen to change the time without the need to first disable and then re-enable the backup scheduler!
Download link (or update directly within BACKUPMON)
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/BACKUPMON/master/backupmon-1.17.sh" -o "/jffs/scripts/backupmon.sh" && chmod 755 "/jffs/scripts/backupmon.sh"
Bravo. That's done the business. Can I stop editing my signature now? 🤓
LOL... for real!! Let's hope so... at least for today! HAHAHAH
@Viktor Jaep I just had a play with 1.17 and notice the cron job being added/modified in services-start doesn’t have the “-backup” switch which means it won’t auto-purge if “Purge Backups =YES” Is this by design or ??
By design... I am going with the simplest option that most people will likely use for the cron job... which is "sh /jffs/scripts/backupmon.sh", which will do a regular backup, and leave it at that. In your case, I would probably just modify the services-start entry and/or the cru entry if you want to add that fancy power user switch... Perhaps in the future, I'll add a feature that allows you to choose to add the -backup switch to the CRON job. ;)
I was bored last night, so I hacked something together to accomplish this:
  1. Copy /jffs/addons/backupmon.d/backupmon.cfg to /jffs/addons/backupmon.d/backupmon1.cfg and /jffs/addons/backupmon.d/backupmon2.cfg.
  2. Edit /jffs/addons/backupmon.d/backupmon1.cfg to disable schedule.
  3. Edit /jffs/addons/backupmon.d/backupmon2.cfg to disable schedule and to edit details for second server (i.e., minimally config items 1-4 from GUI). Be sure that the local drive mount path is different than that in /jffs/addons/backupmon.d/backupmon1.cfg.
  4. Create two mini-scripts — /jffs/scripts/backupmon1 and /jffs/scripts/backupmon1:
    • Code:
      #!/bin/sh
      cp /jffs/addons/backupmon.d/backupmon1.cfg /jffs/addons/backupmon.d/backupmon.cfg
           -- AND --
      #!/bin/sh
      cp /jffs/addons/backupmon.d/backupmon2.cfg /jffs/addons/backupmon.d/backupmon.cfg
  5. Change permissions of two mini-scripts to 755.
  6. Create two crontab entries in /jffs/scripts/post-mount to run the two mini-scripts. I staggered them by 15 minutes.
There may be a more elegant way, but this works like a champ in the interim!
    • Code:
      #!/bin/sh
           -- AND --
      #!/bin/sh
Dang, you rock @visortgw! That certainly does the trick! :) Yeah, I'm toying with it right now, figuring out how to handle the interface to add a secondary backup target, and how it should behave/display when all is said and done. Great job!
When trying to install backupmon on a new router, I am again unable to initiate the initial configuration. Running:
sh /jffs/scripts/backup.sh -setup
results in fatal error:
ERROR: BACKUPMON is not configured. Please run 'backupmon.sh -setup' first.
Any thoughts?
Any thoughts?
This error was originally fixed in 0.92RC. I presume you're using a later version?
