Jan 27 11:07:19 router ejusb[8667]: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:19 router rc_service: ejusb 8667:notify_rc stop_nasapps
Jan 27 11:07:19 router avahi-daemon[5949]: Files changed, reloading.
Jan 27 11:07:19 router avahi-daemon[5949]: Loading service file /tmp/avahi/services/mt-daap.service.
Jan 27 11:07:19 router iTunes: daemon is stopped
Jan 27 11:07:19 router FTP_Server: daemon is stopped
Jan 27 11:07:19 router Samba_Server: smb daemon is stopped
Jan 27 11:07:19 router avahi-daemon[5949]: Got SIGTERM, quitting.
Jan 27 11:07:19 router avahi-daemon[5949]: Leaving mDNS multicast group on interface br0.IPv4 with address 192.168.50.1.
Jan 27 11:07:19 router avahi-daemon[5949]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Jan 27 11:07:19 router avahi-daemon[5949]: avahi-daemon 0.7 exiting.
Jan 27 11:07:19 router Timemachine: daemon is stopped
Jan 27 11:07:19 router avahi-daemon[8681]: Found user 'nobody' (UID 65534) and group 'nobody' (GID 65534).
Jan 27 11:07:19 router avahi-daemon[8681]: Successfully dropped root privileges.
Jan 27 11:07:19 router avahi-daemon[8681]: avahi-daemon 0.7 starting up.
Jan 27 11:07:19 router avahi-daemon[8681]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Jan 27 11:07:19 router avahi-daemon[8681]: No service file found in /tmp/avahi/services.
Jan 27 11:07:19 router avahi-daemon[8681]: Loading new alias name RT-AX88U.
Jan 27 11:07:19 router avahi-daemon[8681]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.50.1.
Jan 27 11:07:19 router avahi-daemon[8681]: New relevant interface br0.IPv4 for mDNS.
Jan 27 11:07:19 router avahi-daemon[8681]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Jan 27 11:07:19 router avahi-daemon[8681]: New relevant interface lo.IPv4 for mDNS.
Jan 27 11:07:19 router avahi-daemon[8681]: Network interface enumeration completed.
Jan 27 11:07:19 router avahi-daemon[8681]: Registering new address record for 192.168.50.1 on br0.IPv4.
Jan 27 11:07:19 router avahi-daemon[8681]: Registering new address record for 127.0.0.1 on lo.IPv4.
Jan 27 11:07:20 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:20 router avahi-daemon[8681]: Server startup complete. Host name is RT-AX88U-F098.local. Local service cookie is 3659585021.
Jan 27 11:07:20 router avahi-daemon[8681]: Alias name "RT-AX88U" successfully established.
Jan 27 11:07:21 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:22 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:23 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:24 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:25 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:26 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:27 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:28 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:29 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:30 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:31 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:32 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:33 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:34 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:35 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:36 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:37 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:38 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:39 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:40 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:41 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:42 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:43 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:44 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:45 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:46 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:47 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:48 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:49 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:50 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:51 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:52 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:53 router ejusb: USB partition unmounted from /tmp/mnt/SamsungT5 fail. (return -1, Bad file descriptor)
Jan 27 11:07:54 router ejusb: USB partition busy - will unmount ASAP from /tmp/mnt/SamsungT5
Jan 27 11:07:54 router rc_service: httpd 5990:notify_rc stop_upgrade
Jan 27 11:07:54 router usb: USB is ejected
Jan 27 11:07:54 router nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Jan 27 11:07:55 router kernel: IDPfw: Exit IDPfw
Jan 27 11:07:55 router kernel: mod epilog takes 0 jiffies
Jan 27 11:07:55 router kernel: Exit chrdev /dev/idpfw with major 191
Jan 27 11:07:55 router kernel: Exit chrdev /dev/idp with major 190
Jan 27 11:07:55 router kernel: Cpuidle Host Clock divider is enabled
Jan 27 11:07:55 router BWDPI: re-enable fc
Jan 27 11:07:57 router networkmap: Error unlocking 0: 9 Bad file descriptor
Jan 27 11:07:57 router avahi-daemon[8681]: Got SIGTERM, quitting.
Jan 27 11:07:57 router avahi-daemon[8681]: Leaving mDNS multicast group on interface br0.IPv4 with address 192.168.50.1.
Jan 27 11:07:57 router avahi-daemon[8681]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Jan 27 11:07:57 router avahi-daemon[8681]: avahi-daemon 0.7 exiting.
Jan 27 11:07:57 router kernel: klogd: exiting
