Bandwidth data content
Gar
I use DirectvNow with my Asus RT-AC56U set to limit data to 5 down and .5 up. 5 down is my optimal value, I can see the changes. I tried raising/dropping the "up" value and saw no picture difference so set it to .5 as a starting point. There is plenty of activity in the uplink according to the Asus app, but only small amounts. What data is going up? Do you think they monitor my programing? I'm trying to share data with all my devices on a 1024gb/mo limit so not wanting to waste it.
Thanks in advance.
Edit: using Roku for TV
Thanks in advance.
Maybe advertiser cookie traffic/monitoring of your browsing ?
What are the ISP nominal down/up bandwith values ?
Cable 100/10
in addition to browsing analytics, windows and other programs phoning home and uploading usage data is another possibility. You could run Malwarebytes and other similar programs to see if anything malicious is going on. Unless you are willing to dive deep, not likely worth messing with.
DTVNow - they will track your viewing on the network side, and yes, they do it for analytics and billing to the advertisers... they don't need to do that kind of stuff on the client App on your end, they do it on their end. You might see some traffic out of band between the client app and their side, and this is likely performance measurement, as ATT/DTVNow are still fine tuning their content delivery platform...
I hate BW caps as much as the next person, but if one is ATT Wireless on the phone/tablet, it doesn't count against caps on those services, and if one is ATT DSL/Fiber, again, DTVNow is zero rated...
The challenge with DTVNow is what your broadband provider is not ATT...
Tip - DTVNow is pretty optimized for LTE/4G, so you don't need an upstream limited, just a downstream, and play with it, might be ok with 1 down...
I have two streaming services - Netflix, and an international service for my Nihongo programming (Japanese TV Broadcast service), along with my domestic TV over DirecTV satellite - but DTV also uses broadband for On-Demand programming..
I use about 250 GB monthly on top of my normal internet usage - I'm thinking your broadband provider is a bit generous with their 1TB month cap there...
I have cable 100/10. If I don't BW limit the Roku it will use 50mbps down on DTV, up is never above 1. At that rate I'd have a week or less of service. Every device uses it except phone calls.
I have run MB and nothing shows up. Delete crap with CCleaner daily.
Dropped uplink to .1, the lowest value, and no issues or performance hit that i can see. Just don't want to provide any more info to "them" than necessary, not sure that this will make a difference.
N WiFi wireless vs cellular data 4g lte or 5g General Wi-Fi Discussion 2
