T
thetoad30
Guest
All,
I thought I understood router streams and bandwidth mode on new N routers.
I had always thought that one stream = one channel = 20 MHz mode on the router in 2.4 GHz. I also thought that 2x2 meant that you could have two streams, and that automatically meant 40 MHz mode (2 channels at 20 MHz each).
Apparently, this is not correct, as you can have a 3x3 router with 20 or 40 MHz mode.
Can anyone please point me to, or explain to me, how these two terms are separate and how they interact with each other? Especially now with 2x3 radios (how does that even work?) and the newer 3x3 radios coming out?
Thank you very much.
