alanwhpoon
Not sure if this is the right forum or even the right site for this question. I have no networking background, and getting frustrated trying to set up my home network!
My telco provided me with an Actiontec T3200 wireless router. As I've been adding more devices I've been noticing wifi performance issues, and after reading online it seems that the best logical step was to purchase a better router. So I purchased the ASUS AC2900 RT-AC68U.
Reading online, here's what I've done:
1. Kept my TVbox connected to the T3200 (apparently it needs to be connected to the T3200 to work properly)
2. Set the T3200 to bridge mode (I still don't know the pros / cons of setting to bridge mode)
At this point, if I connect the RT-AC68U WAN port to the T3200 LAN1 port, everything works great. Except that all my devices have IP addresses of 192.168.50.x instead of the 192.168.1.x that they used to have (not sure if this is a problem?) However, I have some devices connected to the RT-AC68U LAN that require port forwarding, and I don't know if that's possible in this configuration?
Continuing to read online, it seems that I'm supposed to set the RT-AC68U into Access Point mode, and to make sure I assign an IP address before doing this.
1. On the T3200 DHCP settings and assigned 192.168.1.70 to the RT-AC68U MAC address
2. On the RT-AC68U I changed the configuration to Access Point
Once the RT-AC68U reset, it had the correct IP address of 192.168.1.70. Devices connected to RT-AC68U are able to access the internet. However, they have strange IP addresses of 108.172.210.* and I'm not able to access the router configuration page when I go to http://108.172.210.1.
So, I guess my questions are:
- Should the T3200 be in bridge mode?
- Should the RT-AC68U be in access point mode?
- Why am I getting the problem of the strange IP addresses, and not being able to access my RT-AC68U configuration page in Access Point mode?
- Can I enable port forwarding for devices connected to the RT-AC68U?
Thanks in advance!
Alan
Thanks in advance!
Alan
