My AC86U is currently a DHCP server to all LAN devices. The LAN address is 192.168.50.1, subnet mask 255.255.255.0. The DHCP IP pool is 192.168.50.3 through 192.168.50.254. I have added some manually assigned addresses within that pool.
Suppose I want a LAN device not to use DHCP but rather to use an IP address that I specify in the device's configuration. Can I reduce the 86U's DHCP IP pool width and assign the device an IP within the LAN address subnet 192.168.50.0/24 but outside the DHCP IP pool? Or will the 86U drop packets from that address? The same question applies where I assign the device an address from another subnet, such as from 10.0.0.0/8. What does the 86U do with packets from a LAN connection with a source subnet unknown to it?
