Joined forums a couple of weeks ago looking for info that would help guide me on new router purchase. Initially was considering higher priced routers, but after reading reviews and forums here realized this was probably overkill for me.
Currently, I do not have a router, but want to add one for the following reasons:
1.) increase security (only running a software firewall now)
2.) wireless connection to internet (for two 11g clients)
3.) wireless printing (11g wireless printer)
4.) stream NetFlix to PS3 via Cat5e hardwire
Many people on the forums seem to like the EnGenius ESR9850...it has GigE so heat might be a problem, but it ranks high in the charts and is reasonably price. The Asus RT-N13U seems like it would be a good fit, but it also sounds like it is difficult to set up. The D-Link DIR-655 used to be a solid / consistent performer that was very popular, but sounds like there have been some firmware issues in more recent A4 revision...also has GigE and is known to run hot. The Cisco-Linksys WRT-400N is still available, Tim's review seemed favorable and can pick up a refurb for ~$53. Even an old reliable 11g router, like the Linksys WRT54GL would likely work for my setup
I would appreciate it if anyone would be willing to comment / share opinion on the above routers or suggest others in the under $75 category that you think are worthy of consideration.
Thanks,
Frito
Thanks,
Frito
