BE96 Firmware Update 3.0.0.6.102_34777
jixiangyuan
The BE96 (not BE96U) or Octopus 7 (CN only version, without 6GHz) received a firmware update today. You can use this as a forecast of what will come to BE96U/98/98 Pro in the coming month.
Release notes (Translated using Google Translate):
Problem correction and performance improvement
- Improve the connection stability of AiMesh
- Fix v6plus related problems
- Add WPA2/WPA3-Personal as one of the authentication methods of WiFi7
- Fix the Guest Network Pro connection problem of WiFi7 devices
- Fix the abnormal LED light problem
- Fixed the problem related to the device icon on the device list
- Fixed the problem that the system will restart when the rules enabled by parental control are empty
- Support Samba access for IPv6
- Fixed the problem that the device list cannot display IPv6 connected devices
- Fixed the problem related to AiCloud function Multiple issues
- Optimize the user experience of Aura night mode
Security fixes
- Fix CVE-2023-5678, CVE-2024-0727.
- Fix the stack buffer overflow vulnerability in WPS
- Fix the command injection vulnerability.
- Fix the ARP poisoning vulnerability .
- Fix code execution in custom OVPN.
- Fix stack buffer overflow in lighttpd.
- Fix the XSS and Self-reflected HTML injection vulnerability.
*Please note that this firmware version contains many security fixes and we strongly recommend that you update to this firmware version And do not perform downgrade actions. If you need to downgrade to an older firmware version, it is recommended that you manually update the old firmware version and then perform a reset to avoid connection problems.
Please decompress the file first and then use the original firmware file to confirm Checksum
SHA256: eb1f06df669e88f9b575d5b0e9da4b06b46a8185459ebe6c5bc4f3461b618fcb
Link: https://rog.asus.com.cn/networking/rog-rapture-gt-be96/helpdesk_bios/
