Some are talking about poor performance on the AC66U B1.... any thoughts??The last stock firmware for the RT-N19 is from January 2021, it seems a dead product.
I suggest a RT-AC68U or RT-AC66U B1 or RT-AC1900, basically 3 times the same router and fully supported with frequent firmware updates.
Those are 3x3 routers, while most clients devices are 2x2 at best, they will fulfill your needs.
I have a RT-AC68U as main router positioned on the lowest floor, 2.4 GHz does nicely cover two (concrete) floors of our house and even the third floor is quite ok.
For a new purchase I would still prefer a router that get regular firmware updates.
Would you say that the N19 has much better 2.4GHz coverage/penetration than the AC66U B1 ?Specific use product, but with the best penetration 2.4GHz radio I’ve seen on a home router. It beats much more expensive APs. Good for AP use, for dedicated IoT radio.
Realise that the advertised 600 Mbps can in theory only be reached
Welcome To SNBForums
