vaiogeodon
I know 2.4 GHz is better than 5 in range alone, but what commercial router has the best range as far as 5GHz goes. Thank you.
Well Amped Wireless just released the RTA15 and it has twin turbos for 5Ghz!! (2 stage amps) So far the range for 5Ghz is better then the R20000G is. Netflix streams from a greater distance then the other one did for 5Ghz. Sig str on the streaming device was stronger as well.
No. N clients look like N clients to an AC router.Thiggins,
Do regular N clients gain any benefit from going with an AC router especially regarding range?
Welcome To SNBForums
