What are the benefits of Quad9 and Cloudflare over NextDNS? Why do you recommend those instead? Here's what I can come up with pros and cons. I'd like to learn more about them. I realise i'm biased due to using and paying for NextDNS, but I tried the others, and this is my pros and cons list based on a limited knkowledge and research done by me before choosing NextDNS a couple years ago:
Quad9:
+ Independent and trusted by security specialists
+ NPO
+ Free
+ DNSSEC
+ Kinda fast, at 32ms latency
+ Blocks malware from many sources and malicious domains
+ DoH and DoT
+ Email support
- No ad or tracker filtering
- No parental controls or other restrictive features
- no control over lists or security features
- No control panel to configure things such as profiles or filtering
- No Whitelisting capabilities, if something breaks, you have to disable quad9
Cloudflare 1.1.1.1 / 1.1.1.2 / 1.1.1.3
+ Fastest of all, 10ms latency on average
+ Free
+ DNSSEC
+ DoH and DoT
+ Malware protection (but only 1.1.1.2 and 1.1.1.3)
+ Blocks adult content (only 1.1.1.3)
+ Can disable logs altogether, if not they're kept for max 24hrs
+ Email support
- No Whitelisting capabilities, if something breaks, you have to disable 1.1.1.1
NextDNS
+ Quite fast, 20ms (7ms where I live)
+ DoH and DoT
+ DNSSEC
+ Create infinite profiles for familiy members, or devices or whatever
+ Full control over block lists
+ Whitelisting and blacklisting
+ Full control over Parental control and Recreation time
+ Native tracking protections against macOS, Windows, Xiaomi, Samsung, Amazon etc
+ Block DNS-bypass methods such as proxies and VPNs
+ Block disguised third party trackers
+ Block by category such as Tik Tok, Instagram, Facebook, Fortnite etc etc
+ Cryptojacking protection, DNS rebinding protection, IDN Homograph protection
+ Logging in US, EU or Switzerland or NO logging at all if you choose
+ 2FA for logging in
+ Can be installed on any device even routers
+ Works with iCloud Private Relay
- 300,000 queries free per month, after that 1,99$
- No official support, just community support
I think if you just want to set it and forget it, it doesn't matter which one as long as you choose any of them (except 1.1.1.1). If you want something that can be easily setup, set and forgotten, but also have the option to be super configurable and block anything, including ads, then NextDNS.
