Tomo
Hi, i need your advice on the best connection in my network without bottlenecks, considering that now i have not particular problems, it is just to have the best and correct solution. My doubt is how connect my two 8 Lan Switch gigabit to the router, under a pics of my configuration. It's ok or is better connect the router to the first switch and then connect the two switches toghether ?
