efwalter
I am hesitating between several Dual-Band Wireless-N USB Network Adapter below:
Linksys by Cisco WUSB600N Dual-Band Wireless-N USB Network Adapter or TRENDnet 300Mbps Dual Band Wireless N USB Adapter TEW-664UB
http://www.amazon.com/Linksys-WUSB60...&s=electronics
http://www.amazon.com/TRENDnet-300Mb...9&sr=1-2-fkmr0
Trendnet seems to be compatible with WD TV Live if you use it.
I am planning to buy a Netgear RangeMax Dual Band Wireless-N Gigabit Router (WNDR3700) but the netgear dula-band adapter has bad review on Amazon.
Which ones would you recommend for the netgear router?
Emmanuel
Emmanuel
