Best Firmware Combo for Primary GT-AXE1100 (Wi-Fi 6) + AP RT-AC66U_B1 (Wi-Fi 5)
garycnew
Hi All:
I'm trying to confirm the best firmware combo for a Primary Router GT-AXE1100 (Wi-Fi 6) + Access Point RT-AC66U_B1 (Wi-Fi 5)?
I understand that the Wi-Fi 6 technology won't be available via the Wi-Fi 5 devices, but I intend to slowly sunset the Wi-Fi 5 devices.
Is it best to use the latest firmware available for each device? OR Is it best to use the same version of firmware available for both the Wi-Fi 6 and Wi-Fi 5 devices?
Thanks, again.
Gary
Use the latest available for both - it contains security patches for recent malware. You perhaps want Asuswrt-Merlin on the Router, current version is 3004.388.8_4. For the Access Point stock Asuswrt is good enough, latest version is 3.0.0.4.386_51722.
@Tech9
That raises an interesting question... Will Asus continue to support the Official Asuswrt, beyond Asuswrt-Merlin?
I need to execute jffs scripts on the Access Points, so I will need to continue to use Asuswrt-Merlin on them.
I realize the security implications of not using the latest firmware. My primary question is whether the compatibility/usability between GT-AXE1100_3004.388.8_4.zip (2024-11-17) and RT-AC68U_386.14_2.zip (2024-11-17) is the same or better than the compatibility/usability between GT-AXE1100_386.7_2.zip (2022-07-24) and RT-AC68U_386.7_2.zip (2022-07-24)? In a Perfect World, I would prefer Security and Usability. In an Imperfect World, I have a tendency to favor Usability over Security.
Thank you for responding. I was hoping that you would weigh in on this question. ;)
Respectfully,
Gary
No, it happens the other way around - Asuswrt-Merlin support stops some time after Asus support stops.
The routers are different hardware platform and the same Asuswrt-Merlin release is not the same firmware. They run different firmware with the same version Asuswrt-Merlin changes on top. You'll be running Router and AP - compatibility is almost guaranteed. The AP may be different than Asus router and will still work. If you are asking about AiMesh - I don't know if AiMesh part is the same in Asuswrt-Merlin 386.7_2 (or any other the same version) for different routers. They were built on top of different Asuswrt GPL and AiMesh is closed source.
And the "good" news:
GT-AXE11000 is 2 generations behind in hardware (CPU/radios) as of 2024. It is in fact the same GT-AX11000 router from 2018 with one radio tuned for 6GHz band. Don't be surprised if you see it on Asus EoL list in 1-2 years time. The life cycle is shorter now.
I don't know if what you'll be using is going to be compatible with latest firmware releases. I know you have special requirements and you have to find out what works, what doesn't or what needs to be adjusted to make it work. For me your original question has one answer - latest available firmware. RT-AC66U B1 is not the best AP and you have to run it light and on different channels. Otherwise it may negatively impact the performance of your main router. AiMesh - not the best node as well. The one with the most issues reported (RT-AC68U all variants) starting from adopting it into AiMesh system. Asuswrt-Merlin on it and wireless - good luck.
BCM4360 radios used in RT-AC68U variants - really old early AC Wave 1 and started as Draft version, not sure if they ever met the standard fully with driver updates. They may struggle with multiple active clients and will slow down whatever is working on the same channels.
I thought that might be the case, but I appreciate you confirming it.
My firmware compatibility questions are more general in scope. Per your recommendation, I'm planning on moving away from AiMesh in favor of AP's.
"Good" Times for 'Good' News. The GT-AXE1100 is what I have available. It should be reasonably better than the RT-AC66U_B1 and sufficient for my needs. I'll just have to expect to do this, again, in a couple of years--which isn't a bad thing--right? 😂
I'm not too concerned about this as I don't really use the RT-AC66U_B1's as AiMesh Nodes and more for my "Special" needs. However, I do need the RT-AC66U_B1's to work well with the Primary Router in other ways (i.e., NFS, OpenVPN, Wireguard, Tor, etc). ;)
Not available in AP Mode. No WAN and no routing there.
I'm fairly sure the AP's are routable. If there is no routing through the AP's, how do the devices that connect to them connect to the Internet? The AP's WAN port should overload NAT to the Primary Router and then default out to the Internet. Inbound, it will likely require a PortForward or LoadBalanced connection, though. When I get to that point, I will test and let you know. Thanks for the responses.
Access Points are wired-to-wireless bridges.
AiMesh Nodes
Nodes, Satellites, Pods... just fancy consumer marketing names for wired access points or wireless repeaters with different set of extra features. I have simple access points and can do things not available in consumer mesh systems yet. So how it's called by marketing - doesn't really matter. AiMesh is there for convenience and will limit someone like you.
All my AiMesh Nodes are using Wired Backhaul. Curious... Do you know whether Asuswrt AP's can Bridge ("Backhaul") Wirelessly? Thanks, again.
It's called Repeater Mode outside of AiMesh.
I think someone hacked the account. The questions asked are not coming from @garycnew I know. 🤪
I've confirmed that Asuswrt-Merlin AP's are indeed routable and able to host application services.
You can run some scripts there, but what routing your APs do? There is no WAN port in AP Mode.
Hi @Tech9
To test the AP WAN... I reconfigured one of the RT-AC66U_B1 AiMesh Nodes as an AP, connected the AP WAN to the GT-AXE11000 LAN, and installed/configured Entware Tor on the AP (confirming successful communication with the Tor Network).
When you say, "There is no WAN port in AP Mode." Are you referring to the lack of a WAN configuration section in the WebUI?
You may not be able to configure the AP's WAN via the WebUI, but you can configure it from the command-line with Asuswrt-Merlin.
After all... Asuswrt-Merlin is a glorified Linux box.
Respectfully,
Gary
I think there's some confusion here over terminology. As readers of this forum would understand it an AP is not a router. A router has a WAN interface, an AP does not have a WAN interface (the WAN port is reassigned as another LAN port). An (Asus) AP can run many of the services that a router can (e.g. Samba) but it cannot run services that require it to do routing (e.g. packet filtering, NAT, QoS, etc) between the WAN and LAN interfaces, because it has no WAN interface.
When you say your AP is "routable" I suspect you simply mean it is a host device with its own local IP address, just like any other host on the LAN.
