Best Firmware for 2.4 GHz
Poseidon
What is the best FIRMWARE (Factory or Merlin) for 2.4GHz WiFi???
Currently using 3.0.0.4.372.1363 from Asus but I'm wondering if there is a better firmware that delivers stronger, more reliable WiFi on 2.4.....since certain firmwares use different drivers.
Thanks.
What is it that you don't find strong and reliable about .372.1363?
I find it to be very strong and very reliable. No problems.
Maybe if you detailed the problems you're having, someone might be able to help.
asus 270 and 272 versions seem good , i am using merlins 270.26b and i think it is the best for me
