In the past I remember setting up a certain version of a certain linux distro that I could use to compile binaries that were compatible with DD-WRT. Is there a recommendation that works best with what Asus uses?
I see that uname -a shows:
which means it's using ARM, so I'm not sure there is a choice out there. If there isn't a good distro, can anyone point me in the right direction to correctly cross compile (Using linux, OSX, or windows)?
Thanks.
Linux RT-AC68U 2.6.36.4brcmarm #1 SMP PREEMPT Sat Jan 11 15:06:52 EST 2014 armv7l GNU/Linux
Thanks.
