Best router for 100 dollars / 80 euros
BENZiiH
I'm looking for router with gigabit wan/lan and
wlan hasn't to be blazing fast.
Stability and wan/lan performance would be a big plus.
Asus RT-AC56U or Asus RT-N56U any good?
Thank you!
Those two Asus models aren't too bad. If you don't mind loading DD-WRT, a TP-Link Archer C7 might be the best bang for the buck at $100. If wlan doesn't have to be blazing fast, then an N-class device would also work -- more options to look at there, too. If you're skills are up to snuff, a Mikrotik RB951G-2HND will blow the socks off most anything else at its price point for features. GL!
I also highly recommend the TP-Link Archer C7, especially with latest firmware. If you can find the v2 or even v3 version, go for it! :)
