Best router for sharing connection.
Lalato
I'm sure my situation isn't unique. I live in an apartment and am sharing a connection with my upstairs neighbor. Everything is working fine, but there are times when performance lags a bit. I'm wondering if getting a different router might help the situation.
Currently have a Linksys WRT54G v6. This is the so called "neutered" version of the WRT line of routers... so installing all of the features of DD-WRT or OpenWRT isn't really an option. I think there is a "micro" version of DD-WRT that could work, but I have doubts that installing it will increase performance appreciably.
All but one of the current devices are Macs. It's a mix of B/G/N devices. I think my neighbor is B/G (not 100% sure if it's just G or if he also has a B device floating around). In my apartment it's G/N.
Would it make sense to get a dual band dual radio N router? Put my apartment on the 5Ghz radio and the neighbor on the 2.4Ghz radio? If I verify that I have nothing slower than G on the network, maybe just getting a better G router would be best?
Thanks for any advice you might have. :)
--sam
What do you mean "performance lags a bit". Wireless? Yours? Your neighbors?
11b devices will definitely slow things down when they are transmitting.
What I mean by that is that streaming video gets stutters. Download performance isn't as good as it could be at times.
I have the fastest service Comcast offers so I'm pretty sure it's not an issue with the pipes coming into the router. That said, I'm not sure how I would test to rule that out.
If it's a B client, then I'm not sure there is much I can do about it other than tell my neighbor to get a better adapter. Hmmm...
Let me know if you have any other questions. :)
--sam
Streaming video to the upstairs apartment or to your network? What kind of video, web or HD?
I'm trying to figure out if it's just a bandwidth issue.
To keep B clients from slowing things down, you'd need to put them on another AP, set to a different channel and with a different SSID.
sorry about the delayed response. I've been in Portland doing some brewery tours. What a great town.
Anyway, as to your questions. Video streaming in my apartment has stutters. Stuff like Hulu and other services. Come to think of it I guess it could be a problem with those services and not my setup.
Your comment on setting them up on a different AP leaves me wondering if I could convert my current Router into an AP for the upstairs neighbors should I decide to get a new router for downstairs. As noted above, I have the neutered version of the WRT54G line of routers.
--sam
If you're having trouble with Web video in your own apartment, first try a wired connection to rule out problems with the sites themselves or your Internet connection.
Then get your neighbors clients disconnected and all your B clients disconnected and try just streaming with a G client.
If that works, then set up a separate router to handle B traffic or upgrade those devices (if possible) to at least G.
