I have a home PC which is LAN connected to an Asus ac66u router and a Synology DS412SE NAS. Other computers are connected via WiFi and router. Both the router and synology have only USB2 peripheral conntectors. My PC has one USB3 connector.
The Synology is used for work data and other critical storage. The MyBook will be used for movies and other non-critical storage and will be mainly written to via PC and read from via WiFi.
What is the best way to connect that will give the highest streaming speed?
I thought buying a USB3 to Gigabit network adaptor and plugging into a network port on the router. Are there any alternatives?
Or should I just plug it into the router USB2 socket.
