Wilson_Deng
Hi Everyone,
Long time no see~~~
Thanks for using ASUS AiMesh, and we keep moving forward, here are the Phase 2 beta release:
Here are links to AiMesh Phase 2 beta:
******Do remember! This is beta version, might still have some bugs******
RT-AC68U
https://www.amazon.com/dp/B07B316542/?tag=snbforums-20
https://www.amazon.com/dp/B00FB45SI4/?tag=snbforums-20
Firmware:
https://drive.google.com/file/d/1qKuLt5QCJiv9r4xvJlkkHQTNkrvMbYFD/view?usp=sharing
Release note:
- Support Ethernet onboarding (the mesh node search will find Ethernet nodes)
- The wireless schedule could be synchronized of all nodes.
- Support smart-connect rules on nodes. (both dual-band and tri-band) (RT-AC68U series have no smart connect)
- Synchronizing wireless professional settings to nodes.
- Synchronizing schedule reboot to all nodes.
- Synchronizing WPS settings to all nodes. (only enable and disable, this action will not sync trigger).
- Synchronizing region selection to all nodes. (Be noted: this function ONLY works under all nodes were bought in the same region, manual change won't help)
- Now you can use Gmail to do feedback.
***I know you guys will ask for other models,will have, but let's focus on RT-AC68U first.
*** Also, this beta is for 68U, we suggest do not mix model for this first beta. (but if you want to try, just go ahead.)
ASUS BlueCave - The world first Wireless router with a hole on it!!!
https://www.amazon.com/Blue-Cave-Dual-Band-Technology-AiProtection/product-reviews/B078TGQ99B
Firmware
https://drive.google.com/file/d/1y81rV1Lz5ogLt15GUbzu3i-V3UVhAfZN/view?usp=sharing
Release note: first release
* Known issue: still have some OOM issues, if you encounter, please reboot it manually.
Long time no see~~~
RT-AC68U
Firmware:
Release note:
Firmware
