Better Driver for Qualcomm Atheros AR1111 WB - EG?
Valorous
Hello!
New to the forum! I just upgraded to windows 10 for a professional music work station, but I'm having latency in latencymon. ndis.sys usually spikes to 800(us). Overall the current us is fine.
Specs:
3930k
GA UD5 X79
AMD R290x
Samsung Pro 850 500gb
Qualcomm Atheros AR1111 WB-EG Wireless Network Adapter.
In device manager it says I have the newest driver, however it says that about a lot of incorrect hardware, especially graphics drivers. I'm wondering what the newest driver is and if someone can find it for more. I attached a picture. I can use LAN in the meantime but this is not always convenient.
Thank you!
Use the onboard ethernet if you're concerned about latency...
If you must use WiFi, consider other options - the AR1111 is b/g/n if I recall, and it's included with the motherboard to support mostly bluetooth for keyboard/mouse, and as a checkbox feature...
I read up on latencymon, wasn't familiar with it.
What driver version/date is windows reporting? The latest from gigabytes website is 10.0.0.75 dates 7/24/2012.
can you disable the variable speed feature of your cpu so that it gets more consistent results?
http://www.resplendence.com/latencymon_power
Also close all other running software when you run it, of course.
S Lots of 2.4Ghz IoTs, will a 3x3 be better than 2x2? General Wi-Fi Discussion 42
