FlexQoS Black Netflix Thumbnail Boxes and Slow Surfing
Istvanwagon
Hello,
I am experiencing some issues with what I suspect is network balancing. My connection is 200MBps download. Some symptoms I am having are:
* Whenever I load Netflix from any device, the Avatar profiles and thumbnail (static pictures) in the menus do not show; however titles play (on an Ethernet connected-Samsung TV, less reliable on AppleTV via WiFi). Netflix tells me that this is a service interruption issue and not their problem.
* In the evening, when I have some backups running, Netflix does not load on AppleTV
* During the day when kids are on e-school, their devices and others are fine, but my wife often has trouble on her MacBook Air browsing websites (except Facebook ironically)
I have copied the FlexQOS log here. When this log was generated, only the first issue was a problem.
Any thoughts? Thanks!
FlexQoS v1.1.0 released 2020-12-13
Debug date : 2021-01-16 11:24:37-0500
Router Model : RT-AX88U
Firmware Ver : 384.19_0
DPI/Sig Ver : 2.0.1 / 2.212
WAN iface : eth0
tc WAN iface : eth0
IPv6 : disabled
Undf Prio : 2
Down Band : 192512
Up Band : 8192
Net Control : 1:10
Work-From-Home: 1:14
Gaming : 1:16
Others : 1:17
Web Surfing : 1:15
Streaming : 1:11
File Downloads: 1:13
Game Downloads: 1:12
Downrates : 9625, 57753, 9625, 9625, 38502, 19251, 28876, 19251
Downceils : 192512, 192512, 192512, 192512, 192512, 192512, 192512, 192512
Downbursts : 11200, 72000, 11200, 11200, 48000, 24000, 35200, 24000
DownCbursts : 240000, 240000, 240000, 240000, 240000, 240000, 240000, 240000
DownQuantums : 120312, 721912, 120312, 120312, 481275, 240637, 360950, 240637
Uprates : 409, 819, 409, 409, 1638, 819, 1228, 2457
Upceils : 8192, 8192, 8192, 8192, 8192, 8192, 8192, 8192
Upbursts : 3200, 3200, 3200, 3200, 3200, 3200, 3200, 3200
UpCbursts : 9600, 9600, 9600, 9600, 9600, 9600, 9600, 9600
UpQuantums : 5112, 10237, 5112, 5112, 20475, 10237, 15350, 30712
iptables settings: <>>udp>>500,4500>>3<>>udp>16384:16415>>>3<>>tcp>>119,563>>5<>>tcp>>80,443>08****>7
-o br0 -p udp -m multiport --sports 500,4500 -j MARK --set-mark 0x8006ffff/0x3fffff
-o eth0 -p udp -m multiport --dports 500,4500 -j MARK --set-mark 0x4006ffff/0x3fffff
-o br0 -p udp -m multiport --dports 16384:16415 -j MARK --set-mark 0x8006ffff/0x3fffff
-o eth0 -p udp -m multiport --sports 16384:16415 -j MARK --set-mark 0x4006ffff/0x3fffff
-o br0 -p tcp -m multiport --sports 119,563 -j MARK --set-mark 0x8003ffff/0x3fffff
-o eth0 -p tcp -m multiport --dports 119,563 -j MARK --set-mark 0x4003ffff/0x3fffff
-o br0 -p tcp -m multiport --sports 80,443 -m mark --mark 0x80080000/0xc03f0000 -j MARK --set-mark 0x803fffff/0x3fffff
-o eth0 -p tcp -m multiport --dports 80,443 -m mark --mark 0x40080000/0xc03f0000 -j MARK --set-mark 0x403fffff/0x3fffff
appdb rules: <000000>6<00006B>6<0D0007>5<0D0086>5<0D00A0>5<12003F>4<13****>4<14****>4<1A****>5
filter change dev br0 prio 2 protocol all handle 828::800 u32 flowid 1:17
filter change dev eth0 prio 2 protocol all handle 828::800 u32 flowid 1:17
filter add dev br0 protocol all prio 2 u32 match mark 0x8000006B 0xc03fffff flowid 1:17
filter add dev eth0 protocol all prio 2 u32 match mark 0x4000006B 0xc03fffff flowid 1:17
filter add dev br0 protocol all prio 15 u32 match mark 0x800D0007 0xc03fffff flowid 1:13
filter add dev eth0 protocol all prio 15 u32 match mark 0x400D0007 0xc03fffff flowid 1:13
filter add dev br0 protocol all prio 15 u32 match mark 0x800D0086 0xc03fffff flowid 1:13
filter add dev eth0 protocol all prio 15 u32 match mark 0x400D0086 0xc03fffff flowid 1:13
filter add dev br0 protocol all prio 15 u32 match mark 0x800D00A0 0xc03fffff flowid 1:13
filter add dev eth0 protocol all prio 15 u32 match mark 0x400D00A0 0xc03fffff flowid 1:13
filter add dev br0 protocol all prio 20 u32 match mark 0x8012003F 0xc03fffff flowid 1:15
filter add dev eth0 protocol all prio 20 u32 match mark 0x4012003F 0xc03fffff flowid 1:15
filter change dev br0 prio 22 protocol all handle 802::800 u32 flowid 1:15
filter change dev eth0 prio 22 protocol all handle 802::800 u32 flowid 1:15
filter change dev br0 prio 23 protocol all handle 804::800 u32 flowid 1:15
filter change dev eth0 prio 23 protocol all handle 804::800 u32 flowid 1:15
filter change dev br0 prio 2 protocol all handle 828::802 u32 flowid 1:13
filter change dev eth0 prio 2 protocol all handle 828::802 u32 flowid 1:13
Please use the Insert Code boxes and input the log within. Pasting it into the main message makes it very hard to read.
Sorry about that...
WAN iface     : eth0
tc WAN iface  : eth0
IPv6          : disabled
Undf Prio     : 2
Down Band     : 192512
Up Band       : 8192
Net Control   : 1:10
Gaming        : 1:16
Others        : 1:17
Web Surfing   : 1:15
Streaming     : 1:11
Debug date    : 2021-01-16 23:12:29-0500
WAN iface     : eth0
tc WAN iface  : eth0
IPv6          : disabled
Undf Prio     : 2
Down Band     : 192512
Up Band       : 8192
Net Control   : 1:10
Gaming        : 1:16
Others        : 1:17
Web Surfing   : 1:15
Streaming     : 1:11
Downrates     :    9625,    9625,    9625,    9625,   38502,   19251,   28876,   19251
Downbursts    :   11200,   11200,   11200,   11200,   48000,   24000,   35200,   24000
DownQuantums  :  120312,  120312,  120312,  120312,  481275,  240637,  360950,  240637
Uprates       :     409,     409,     409,     409,    1638,     819,    1228,    2457
UpQuantums    :    5112,    5112,    5112,    5112,   20475,   10237,   15350,   30712
This is from later this evening when the network should be quiet and we are basically only trying to load Netflix and cannot.
