Hello everybody,
I'm currently running into an issue where when I try to select a Manual Media Server Path (by clicking the box that says "Please select"), I just get a blank area where I should be seeing my directories on the USB drive connected to my RT-AC68A. See attached screenshot. I should also add that this device is running as an AiMesh node under a RT-AC68P router. I have no problem seeing & selecting the directories on my USB drive when setting up FTP and Samba, but for whatever reason it doesn't show when trying to select it under Media Server. Therefore, I don't believe this is a browser issue (I also tried from different PCs with different browsers, same issue). I would really like to be able to specify specific directories instead of sharing everything with the "All Disks Shared" option. The USB drive in question is an external WD 4 TB drive formatted to EXT4, with about 2 TB worth of videos, music, and pictures on there. I have a small USB stick connected to the USB 2.0 port set up as swap. I didn't have this problem before, and it popped up up after doing a factory restore after a firmware upgrade recently. Currently both my main router and AiMesh node are on Merlin FW 386.4. Been using Merlin FW for years and it's been awesome. Also wanted to say that I've tried steps listed here, even though my specific problem isn't mentioned: "https://github.com/RMerl/asuswrt-merlin.ng/wiki/Minidlna:--Common-Issues-&-Solutions". I also tried via http and https. Please let me know if anyone has any ideas to try or if someone's run into this before and has a solution. Thank you all.
