Block AI Crawlers
kramttocs
[Edit: When hosting an exposed /internet facing site] Is there currently a way to flat out block AI Crawlers at the router level?
User Agent blocking?
Edit: I am handling it at the nginx level per host but asking if the router (or Skynet) can handle it at that layer.
Sure. Do not have a web site behind the router or open ports/port forward.
Well, yes but...
Ai and Web crawlers look for web sites. If you have no ports open or forwarded and you have AiCloud and etc. disabled the crawlers will be stopped by the router firewall.
My fault. I didn't assume anyone not hosting a site would ask how to block them. I've updated the first post to clarify.
I do appreciate the replies but you aren't understanding my ask.
Maybe someone else on the forum knows a way though.
https://serverfault.com/questions/690870/iptables-block-user-agent
Maybe there is something within entware, but I personally run Fail2Ban on the Nginx server (offload everything from the router as much as possible) and add offender IPs from the fail2ban.log to a blacklist that then gets added to an IPSET block on the router
Thanks. I am also using Fail2Ban and it's actually what is catching the status codes that nginx is spitting out and banning them (temporarily) that way. Which does work well.
Fair point in keeping things off the router.
