"Block internet access" toggle in Client Status GUI doesn't stick
Luboknok
When toggling the "Block internet access"switch under the Client Status entry for any particular device, it doesn't actually apply the change. The switch toggles then I press the "Apply" button. When checking the device is still in it's original state (blocked or active). I've noticed this issue on numerous Merlin revisions across three routers, currently AX88u Pro. Once in a while it works properly. Am I missing something?
Seems to be working fine on a RT-AX86U Pro running Asus-Merlin 3004.388.7.
Check the Parental Controls > Time Scheduling section in the router GUI. That is where one should see a list of devices that have time scheduling (like blocking internet access) listed.
Examples:
Editing a Time Schedule Entry:
Network Map entry:
Same for me, running 388.7 on 4xXT12s in wireless backhaul. Same behaviour via web UI and Asus app.
I think the issue first appeared on 388.6, and the feature used to work flawlessly before.
It is working flawlessly at my RT-AX88u Pro.
@Luboknok
Did you accept the privacy policy? Maybe this is necessary for proper functioning.
